ELETT1
#1 Posted : Monday, July 9, 2012 6:12:24 PM(UTC)
ELETT1
i have checked the check value its working took bottom spray arm out it is getting water there and motor is turning but spray arms are not turning
#2 Posted : Tuesday, July 10, 2012 3:00:22 PM(UTC)
Check the water level inside the dishwasher.
Remove the volute cover (#10 at the diagram) and check the impeller.
Here are the breakdown diagrams and Replacement parts for Frigidaire FDB510LCS0 Frigidaire/dishwasher | AppliancePartsPros.com
ELETT1
#3 Posted : Thursday, July 12, 2012 10:05:58 AM(UTC)
ELETT1
i can take and add cup of water and it will turn the top spray arm but the bottom will still not turn or spray water
#4 Posted : Thursday, July 12, 2012 12:17:04 PM(UTC)
The system is designed to operate only one spray arm at a time. During the first wash and first and second rinses, only the lower spray arm operates. In the second wash, third and fourth rinses the spray arms alternate about every 90 seconds.
You can learn how it works more detailed by reading the attached file.
File Attachment(s):
WATER DISTRIBUTION SYSTEM.doc (262kb) downloaded 15 time(s).
