I am also getting the motor is not rotating properly message. Does anyone have more info on this?
I have a ge profile harmony wpgt 9350c0ww the screen reads THE MOTOR IS NOT ROTATING PROPERLY CHECK AND REPAIR. I have changed the hall sensor but still doing the same. Any ideals?
Hello, So..my profile washer is showing this message. I went through the steps to get the error coded and what I found was. "The motor is not turning the unit properly".
Can I assume the motor is bad or is there something else I should be looking for?
Thank you for any help!
Bill
washer had error message after I washed kids jeans. unplugged it and couldn't get it off that 'error' screen. After reading your blog.. followed through and WALA! the washer is great! You guys are awesome. Thank you!!! It's so great to have knowledgeable people advising the rest of the population how a possible quick fix can work - :)
Help!!!
Have a Harmony washer machine that the display went out.Model WPGT9360E0PL Determined that main board went out on. Replaced boardand display came back but shows "Problem has been detected with unit" andthen display goes off. Tried the Back and Cycle for 3 seconds thing and it justbeeps and the display goes off again. Can't get it to do anything. I'm assumingI need to reset it but can't figure out how. Any help would be appreciated
Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Just replaced control board and now it codes something wrong with unit and went through everything you said for that other guy and pulling my hair out HELP Thanks Tammy L
