steve rogers
#1 Posted : Tuesday, March 31, 2009 4:46:21 PM(UTC)
steve rogers
I have voltage to the motor control module but nothing works. THe module smells burnt. Is this the problem?
TechnicianBrian
#2 Posted : Tuesday, March 31, 2009 5:53:41 PM(UTC)
TechnicianBrian
If you have voltage to the module and nothing works, the module is the likely failure. Before replacing, it is advised to check the resistance on the drain pump and divert valve to make sure neither one is shorted and may be the cause of the board failure.
