AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Washer puts water in drum does not turn only hums and water does not drain
My LG WM2277HW will start to fill with water but the drum will not rotate, only hums, and in about 4-5 minutes the LE code comes up. The washer does not drain the water, only does the LE code. The washer is 8 years old. Replaced the Drive Motor Stator Assembly part AP4438648 and the Rotor Assembly part AP4438635. However, still have the same problem. Do I need to replace the Wiring Harness part AP4439126 or is it some other problem? I looked at the wiring harness and no outward sign of problem (no frayed wires or obvious damage).
Does anyone know why my washer drum wont move. the light dims but it doesn't move
Washer Repair
