I read the info posted by Brian <title>Appliance Repair Blogand I have the same dryer, same problem, but I can't tell for sure if the squeak is coming from the right side or not. can I take the bearings and and visually tell if they are bad? If so, what do bad ones look like? :confused: thanks
It is difficult to tell if a bearing is bad, but if you remove the bearing, clean it and then reinstall it, the noise may change or go away. Then at least you know if the noise is due to the bearing or not.
thanks--I'll try that and see what happens
Replace the bearing, that is your problem. When you remove the old bearing, be sure to clean the area out with some nail polish remover. When you asked what a bad bearing looks like, you will see a dark color looking grease. The would be the bearing bleading. What a great dryer. Top Loader. Tom ApplianceEducator.com
Thanks. I just hope I can find someone who will sell me the bearings!
The bearing comes as a kit and it is actually not a bearing but a brass bushing so you will not find any grease. The new bearing kit comes with a thin white lubricant that should not be cleaned off prior to installation. Contact Fisher & Paykel and see if you can get the part from them, or they may refer you to an authorized servicer. If you have any trouble getting the kit, let me know as I usually have them in stock.
that is so wrong. there is no greese, that comes with that bearing. if parts select cannot sell you that bearing, i can. i am a fisher & paykel rep. tom www.applianceeducator.com/parts.html
I am praying one of you guys sees this quick!! I am in the process of replacing the bearing mentioned above and the inlet bearing retain er (the gold ring with holes that you screw into place before putting on the thrust washer-at least I think these are the correct names) does not lay flush against the plate because the bearing diameter seems too big. I guess the other was worn down, but should the retainer stand out about 1cm from the plate? Seems like when I put in the screws it will be strained. Does this sound right?
I finally figured out how to put that ring on and now my dryer is purring like kitten. thank you guys so much for operating a forum where you don't charge for your expert advice. If you ever need advice on babies (I'm a neonatal nurse), I'm your girl!
