Frigidaire side by side fridge is freezing. Model number: Frs23bh6cs0
Freezer seems to be working fine
I did turn the fridge side off until I heard the damper door close, then turned it on to setting 2 well below factory setting. Still freezes everything. Please help
Thanks James
Groups: APP Team
Hi, James. First adjust the freezer temp to warmer setting. Give it 12hrs and check freezer temperature. See if that make a difference in the refrigerator side. If at let say 0*F in the freezer it still be freezing produce in the fresh food then replace the damper thermostat #21 Part number: 240383703
Awesome! Will try tonight. I'll post the results tomorrow.
James
Adjusted the freezer control to warmer temp. No change in fridge. Everything is still frozen.
Groups: APP Team
What is the freezer temp.? If it around 0 F - replace the control I mention earlier.
Thank you.
Simon.
I'm embraced to say it but I can't find my thermometer. I'm going to go get another tonight and re run the test. I'll post an update
James
Simon,
Confirmed temp in freezer is just above zero.
James
Groups: APP Team
Hi.
Replace the cold control. You have the info.
Simon.
Thank you so much! I can't tell you how much I appreciate your help.
James Barbero
Groups: APP Team
