mlust
#1 Posted : Tuesday, March 31, 2009 6:27:16 AM(UTC)
mlust
Hey all,
After attempting to auto clean the upper oven, the display went blank. When I reset the breaker, the upper oven fan runs and both ovens lights work, but the display is still dead and the upper oven door lock is still engaged. Is this the control board/display panel or is there a fuse that can be replaced?
#2 Posted : Tuesday, March 31, 2009 7:59:32 AM(UTC)
Here is a wiring diagram
ftp://ftp.electrolux-na.com/Pr...assomption/318046110.pdf
You will see a SAFETY THERMOSTAT in the UPPER OVEN which cuts power to the transformer. Perhaps this is open.
ftp://ftp.electrolux-na.com/Pr...assomption/599532045.pdf
I believe the thermostat is Item 119 on Page 4
Be sure to unplug or cut the power to the unit before working on it.
240 volts is lethal.
