My microwave je1540wv002 recently started to have the same problem and came across this site. Microwave works fine but light on and turntable turns when door is open. Please advise which parts # to replace.
Any easy fix besides taking it in? Not handy with electronics.
Groups: APP Team
Hi. All you need is a basic skills and common sense to replace the door switch. Provide the complete model number so I can get you the part number.
Simon.
Thanks Simon! PEB1590SM1SS
Groups: APP Team
Remove what cover? The panel with the buttons? Can I assume that when I remove the 'cover' that it will be obvious how to 'perform continuity test'. Again, I am not handy with this kind of thing.
Groups: APP Team
Ah yes a multimeter, I have dozens of them. Going to the repair shop now, thanks!
I have recently had the same problem, and found this thread. We have a GE PT970S. At first, we noticed the turntable would turn when the door was opened. This lasted a few weeks, and then we noticed the turntable would stop turning and nothing would heat, but sporadically, the turntable would start again and then it heated food fine. Now, the turntable no longer spins and if I check it, the motor seems to be turning freely (there is not the normal motor sound you should hear if you spin it by hand). I checked the coupler, and it looks fine. I am curious: 1) Could a bad motor also stop the microwave from heating? 2) If not, does it seem plausible for a motor and a switch to go out at the same time on a 4 year old microwave? 3) Is it hard to separate the microwave from the oven in order to service it?
THANKS!!!
[FONT="]I have a GE Spacemaker XL microwave (Model JVM1350AW002), and I have similar problem. Recently I noticed that when I opened the door the light and fan came on however the turn table didn’t not move. I tested it with a cup of water and it didn’t heat when door is open. Other than that, it works fine. What do you think the problem might be and how to repair it? Thanks.[/FONT]
