73TR6
#1 Posted : Monday, June 18, 2012 8:25:53 AM(UTC)
73TR6
Took the thermal fuse to an appliance parts store, they said it was fine.
Took the door switch off, had them check it as well, said it was working intermittantly, so I replaced it. Still nothing. Control Panel lights come on, igniter does not glow, drum does not spin. Any clues?
allen9258
#2 Posted : Wednesday, June 27, 2012 9:00:52 AM(UTC)
allen9258
try checking your push to start switch
#3 Posted : Wednesday, June 27, 2012 6:40:11 PM(UTC)
Make sure the belt is not broken.
If the dryer is less than a year old, why you trying to fix it? It is still under the warranty.
Here are the breakdown diagrams and Replacement parts for Maytag MGD9700SQ0 Gas Dryer | AppliancePartsPros.com
