lightninskyhop
#1 Posted : Tuesday, June 26, 2012 6:26:10 PM(UTC)
lightninskyhop
I removed the control thermostat and the outer thermostat( just a plastic housing with a wire in it -it looks like) The inner 3 terminal thermostat has no continuity at room temperature, so I would think that needs to be replaced.
My question is, is the faulty control thermostat what is tripping the breaker when any heat setting is engaged on the timer? The fluff runs fine on the dryer.
Should I check something else in the heat control circuit also?
#2 Posted : Wednesday, June 27, 2012 5:28:07 PM(UTC)
There is a short somewhere in the heating circuit. You have to check all parts and wires in the heating circuit per the wiring diagram (attached to the post).
Here are the breakdown diagrams and Replacement parts for General Electric WSM2780DAWWW Washer dryer combination | AppliancePartsPros.com
File Attachment(s):
31-15536 - WSM2780DAWWW.pdf (871kb) downloaded 21 time(s).
gas dryer trips breaker when rying to heat (Dryer Repair)
by garrywith2rz 9/30/2009 12:41:02 PM(UTC)
gas dryer trips breaker (Dryer Repair)
by cerriel 2/20/2009 4:24:09 AM(UTC)
