Spring in the soap dispenser slide door has come off and I would like to reconnect it to the slide door.
The instructions are attached to the reply. Gene.
I do not believe that I have ever had a more frustrating experience in attempting to retrieve information. Why doesn't the info come through without contacting NASA then going to Disney?:( I truly give up, Moerke:)
Originally Posted by: Gene  The instructions are attached to the reply.
Gene. Gene how do I take the sliding soap dispenser door off to re-engage the spring, my model number is SHU3032 Thx
Carefully pull the lid up on one side to release it from the rail.
