dryer getting too hot . it was broken I changed the coil-valve and the sensors now it dryes but it gets way too hot creates condensation . any HELP would be great THANKS
Originally Posted by: ray4005  dryer getting too hot . it was broken I changed the coil-valve and the sensors now it dryes but it gets way too hot creates condensation . any HELP would be great THANKS I changed one coil and flame sensor. then realized that when i put it back together the duct had losened from the air duct assembly that was why i was having a condensation problem. by only changing one coil it dont get too hot but it still dryes the clothes. problem fixed.
Hi Ray,
Just wanted to say thank you for sharing with us your diagnosis and repair. It will help other people with a similar problem.
Thanks again and good luck with your dryer.
