2 Pages<12
#11 Posted : Tuesday, June 26, 2012 12:36:03 AM(UTC)
These hard start kits damage the new R134A compressors. Bad idea to use one. They deliver suficiently high currents to start the compressor, but levels way behond design limits particularly during power surges.
kuey
#12 Posted : Tuesday, June 26, 2012 6:17:06 AM(UTC)
kuey
If the new start device did not fix the problem then the compressor itself is bad. The mechanical part of the compressor (pump) has more friction than it should and motor is not able to start it.
There are three solutions.
The first and very expensive is to replace the compressor. You can not do it yourself and it will cost you about $650 - $750. You probably will have one year warranty on it.
The second is to install the 3-in-1 start booster. It has more power torque and will make the compressor to run. It cost just $15.60 but nobody cab tell you how much longer it will last after this repair. It can be a few more years or a few more days.
The third is to shop for a new refrigerator.
- The 3-in-1 start booster Part number: TJ90RCO410
That sucks! I will try option two, is it easy to install? Thanks for your help.
#13 Posted : Tuesday, June 26, 2012 7:28:50 AM(UTC)
I will not help you put on a device that will damage the compressor, these devices are marginally good on the old, pre 1995 compressors with R12 refrigerant.
kuey
#14 Posted : Tuesday, June 26, 2012 1:58:28 PM(UTC)
kuey
So its not worth trying? right now i'm just going to throw the unit away and buy a new one.
#15 Posted : Wednesday, June 27, 2012 11:50:50 AM(UTC)
Hi Rich,
In such situation I disagree with you. His choice is: to give it a try and make this fridge work for some time (the value of risk is less than $16) or throw it away and by a new fridge. It is worth to try.
#16 Posted : Wednesday, June 27, 2012 11:57:42 PM(UTC)
To use this item is not profesional and has caused house fires. Not very wise considering the use of an unsafe product may just void his insurance.
kuey
#17 Posted : Thursday, June 28, 2012 6:37:47 AM(UTC)
kuey
Hi Rich,
I Agree, its working fine with the three way so far.
#18 Posted : Thursday, June 28, 2012 7:20:35 AM(UTC)
I agree with your choice Kue,you have the right to do what you want.
My point is I will not approve or suggest the use of this item based on data and reports showing it can be dangerous during power surges and sudden compressor failures which might occur with your compressor.This is based on my professional attitude and big concerns about liability.
As a servicer and a responder on this forum, I view this use of this item as highly not recomended based on the above.
I suggest you put a 1000 joule surge protector in the wall outlet, I use a Belkin F9H100-CW $6.99 at Amazon. Good luck with it.
#19 Posted : Thursday, June 28, 2012 12:02:15 PM(UTC)
It's always a good idea to use a reliable surge protector for any appliance in your household.
AMANA overload relay replacement (Refrigerator & Freezer Repair)
by cc703 8/28/2007 3:43:45 PM(UTC)
2 Pages<12
