NEED TO KNOW HOW TO RUN DIAGNOSTICS ON MY DISHWASHER SHE46CO6UC / 33 tried a different one that didn't list my model and it didn't seem to work. Any help would be appreciated.
Thanks!!!!!
What seems to be a problem with your dishwasher?
control panel went a few months back and replaced that. Now it fills up and won't drain. Pump or something sounds really load when we start it up. Kindy a dissappointed because I spent the extra money on the Bosch so I wouldn,t have these kind of problems.
Remove the toe panel and check for 120 VAC to the drain pump while the control calls for drain. Post the results.
Which part did you call "control panel"?
Originally Posted by: bmoody  control panel went a few months back and replaced that. Now it fills up and won't drain. Pump or something sounds really load when we start it up. Kindy a dissappointed because I spent the extra money on the Bosch so I wouldn,t have these kind of problems. I couldn't agree more about the spending extra for a bosch, mine has been nothing but problems...next time i will buy a kenmore and just through it away when it breaks down... my old kenmore was way more reliable.
Originally Posted by: nascarcoxy  I couldn't agree more about the spending extra for a bosch, mine has been nothing but problems...next time i will buy a kenmore and just through it away when it breaks down... my old kenmore was way more reliable. The key word in your post is "old". Gene.
Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Does it have a drain filter
