hello-my 3 year old mid size 45x18x18 two door refrig & freezer stopped working for no apparent reason. outlet and circuit breaker ok. what might be the cause and how can i repair it? thanks-chris
What is the complete model number of the refrigerator?
Gene, Thanks for replying. After a few days, I decided to plug my unit back in. It began to work again and has been fine...refrigerator and freezer. I'm glad I wasn't in a hurry to get a replacement. What do you think may have caused the shut down then start up of this unit? It has been very very hot here and I have the frig in a storage area that does not have AC but is next to an air conditioned area. Could this have had anything to do with it? Might it happen again? Thanks-Chris
Originally Posted by: Baseball Dad  ...It has been very very hot here and I have the frig in a storage area that does not have AC but is next to an air conditioned area. Could this have had anything to do with it? Might it happen again?... Hi Chris, Ambient temperature is very important for refrigerator performance. If it's very hot outside the refrigerator and you can not control it, then it's better not to use it. Gene.
Thanks for the advise Gene. I will keep it in mind. I'm glad the unit works again. Regards-Chris
