Sharp model # R-310FW with damaged display board. Oven operates normaly but no display. I traced the problem to: Q1 and R1. Anyone know the part #(IE:2N222) for Q1? or know the mode of failure in this unit with these symptoms? Or know where I can find the part # for Q1 with out spending the $$ for a complete manual-n-schematic?
Thanks.
Rank: Administration
We don't have much info for Sharp. Try calling PacParts at 800-421-5080. They specialize in parts for Sharp, Sanyo, Samsung, etc. You can also try taking the board to your local electronics supply. They should be able to supply separate components for this board.
Hope this helps.
