Hello everyone.
I have an over/under Kenmore washer/dryer combo that sounds as if there are screws loose on the outside of the dryer drum when it is turned on. It can also sound like a wrenching rubbing noise. Any suggestions?
Thanks in advance.
What is the complete model number of the unit?
Gene,
It is kenmore model 131639100D (0503).
Thanks, Chris
Hi Chris,
The model number you posted is not a valid Kenmore model number. Verify and repost it please.
Thanks gene. I'll update and repost.
Ok. The correct model # is 131719300 9711.
Thanks, Chris
Chris,
Where did you find it? The model number should be on top of the dryer, on the dryer door frame or under the washer lid.
Gene, Sorry I just saw this message. I will look again for a different model number. Thanks, Chris Originally Posted by: Gene Chris,
