i have a whirlpool duet dryer that runs fine at times. after a full cycle the digital control stays on touch up and wont start. i can move the dial around to different settings but it wont change from touch up. sometimes it runs after and hour or so but today hasnt started at all. help! cleaned the moisture sensors and terimals but didnt help
I am having similar problems out of a DHZN-ELE-2408024-EL54. I almost bought a board today but decided to keep trying to figure this out. When I reinstalled the board the unit ran like new. There are times when the power will not turn on at all and once it ran without the heating element coming on. This dryer is only 4-years old and has not been used a lot.
