bicycle
#1 Posted : 13 years ago
bicycle
My Maytag washer model LAT5914AAE only fills, agitates, drains, and spins on delicate cycle. On normal/regular cycle it fills but doesn't agitate, drain, or spin; the timer however moves along to the end. Thank you for your help!
Simon / APP Team
#2 Posted : 13 years ago
Simon / APP Team
Groups: APP Team
Hi.
Using the multimeter check if the motor gets 120v between BK and WH wires at the motor switch, timer set on regular.
If no voltage - replace the timer Part number: 22001252
If there is 120v - replace the motor Part number: 12002353
Here are the breakdown diagrams and Replacement parts for Maytag LAT5914AAE WASHER-TOP LOADING | AppliancePartsPros.com
Good luck. Post the results.
Simon.
washer only works in delicate cycle (Washer Repair)
by ric 18 years ago
