My trouble started with the bake button not working. I used the convection bake with worked ok. Next day the bake button work but the beeped and shutoff. Tried the convection and it started but started beeping then I got code F2:E3. Now no matter what button I use I end up getting that same code. I can not find what this code means. Thank you, Brian
THIS FORUM IS DEAD!!!!!!! |
Thank you for your help, I pulled the control panel and there are some clear relays that look like the points are burnt. So I think I need the whole assembly. Thanks again, Brian
