bfawcett
#1 Posted : Sunday, March 29, 2009 4:42:33 PM(UTC)
bfawcett
after using oven it won't turn off until I turn off circuit breaker. Then is OK until next time I use oven. It acts like a relay sticking. :confused: Which part do I replace?
#2 Posted : Monday, March 30, 2009 5:10:14 AM(UTC)
Replacement parts for WHIRLPOOL KERA205PWH4 | AppliancePartsPros.com
Here is the tech sheet
https://www.servicematters.com/d...eet%20-%20W10046430A.pdf
Does sound like the Control Board Item 57 in the "Chassis parts" section.
I would run the diagnostics, perhaps this will confirm that the board is bad.
