refrigerator won't defrost
A model number may help others help you |
THIS FORUM IS DEAD!!!!!!! |
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
The model number formy coldspot refrigerator is:1066696022.The motor and coils,plus the defroster timer are on bottom under refrigerator section.Have been unable to locate defroster thermostat
Have been unable to locate defroster thermostat I had the same problem. The unit does not come up at AppliancePartsPros. At the Sears site it does come up as Item 50 in the Unit Parts diagram. It should be clipped onto the evaporator coils. I was able to find it at AppliancePartsPros using the part number Part number: AP3108444
Click on the picture for more info. |
