Jdb929
#1 Posted : Monday, June 18, 2012 5:28:03 PM(UTC)
Jdb929
The washer does not spin out fast enough to get the clothes dry, they are still soaking wet after the final spin.
#2 Posted : Tuesday, June 19, 2012 5:15:16 PM(UTC)
Tilt the washer back. Remove the belt and check it. Check how freely the drain pump pulley is moving in both directions.
Post the results.
Here are the breakdown diagrams and Replacement parts for Maytag MAVT446AWW WASHER-TOP LOADING | AppliancePartsPros.com
