Defrost cycle stays on too long.
What is too long?
Defrost on this unit should be about 25 minutes. |
THIS FORUM IS DEAD!!!!!!! |
The year of the unit is 1993. I have not timed the defrost cycle but it is on long enough to melt the ice cubes. It seems to only happen in the summer when the Power Saver/Moisture setting is on the moisture setting.
When I read your reply I thought this will be easy but then I read the last line and that threw a monkey wrench into it.
The way defrost works is that every 6 hours [depends if the timer is wired for continuous or cumulative (compressor on time)] a 25 minute defrost cycle is started. Defrost time is set but the defrost thermostat shuts the heater off once the ice/frost has melted. It opens just above freezing.
So melting ice cubes could be due to a bad defrost thermostat. Problem is that it also is related to the ambient temperature/humidity and a thermostat problem should not be affected by this.
I would start by checking the freezer temperature. It should be between 0 and 5 degrees F. Check that the condenser coils under the unit are clean. Check that the vents in the kick plate and rear cover are clean. Check that the condenser/compressor fan is on whenever the compressor is on. Also that the fan blade is clean. Check the door seals. |
