Replaced the three coils worked for a month. Now all I get is a glow and No flame. Is it time to abandon fix and buy new? Help please.
How long time the igniter stays On (glows)?
Hi Gene, It glows for 20 seconds,then i can hear a click for when the flame should kick in ( but it does not) then it takes another 10 secs to shut off. After a bit the process repeats itself.
Thanks Gene. The flame sensor checks out for continuity, however the white wire connector seems a bit loose. Could this be the problem? If I order a new part will the white wire connector fit better?:confused:
Nope not that, I repaired the connector...still no flame , will try replacing the flame sensor
I give ....time to replace.
It can be a bad gas valve but it's not worth to replace it. Too much $$$
