I have a Kenmore gas stove model #911.7398911 and it is 21 yrs. old. I can't find my model on your site.
Whenever I turn on my oven, it makes a boom noise, also when oven is cycling on and off. I have had my igniter replaced once about 8 yrs ago or so because it was doing the same thing at that time. It helped for a few months or so and started booming again. The oven works fine with the exception of the big boom.
Is this an igniter problem? Also, if it is, I will be doing this myself and I'd like to know if I need to turn the gas OFF in order to replace it.
Thank you!
This could be an igniter problem causing delayed ignition which will be associated with a popping sound, but you are describing a booming sounds which I would be a bit more concerned with. This would indicate to me that gas is flowing, then igniting in a large quantity, which could still indicate an igniter, but may also be the burner itself. If the ignition holes near the igniter are obstructed, then the ignition point is further away from the igniter and more gas is needed to get back toward the igniter. I would replace the igniter due to age, and while you are in there, make sure the burner is cleaned (take it out if you need to) and all the holes are open. Also, ensure it is mounted correctly over the orifice (it should only go on one way) then give it a try. You don't need to turn off the gas to change an igniter, but do turn off the electricity.
Thank you, Brian. I normally use your websites super appliance diagrams, but can't find for my stove. S***S dot com, where I bought my appliance many years ago, has a diagram, but it isn't clear. Could you tell me what is entailed in removing the burner and what do I use to clean it? I see that I don't need to turn off gas to change igniter, but do I need to turn off the gas to remove the burner?
Thanks a lot for the help. :)
You will need to remove the bottom oven panel first, which usually pulls up from the back and then can be worked out of the cavity. Below will be the flame spreader which is usually held in place with couple screws. Below will be the burner and it too is held in place with a few screws. One end will fit over the gas orifice and try using the end of a paper clip to push into each of the holes to make sure they are clear. The gas doesn't need to be off to do this.
