mom01
#1 Posted : Sunday, March 29, 2009 6:27:30 AM(UTC)
mom01
the belt is getting jammed on the motor pulley was told its the pump because the pump pulley doesn't turn by hand Can I service the pump or do I need new one??
TechnicianBrian
#2 Posted : Sunday, March 29, 2009 7:06:01 AM(UTC)
TechnicianBrian
You can open up the pump (AP4372886) and see if there is something inside, but I would then replace it due to age and what ever is in there probably didn't make it any better. If you do find something, at least you can clean it it out until the new pump arrives.
mom01
#3 Posted : Sunday, March 29, 2009 7:31:11 AM(UTC)
mom01
I did do that found a little necklace of my daughters removed it put the pump back together and thats when the belt melted! Maybe theres more under the impeller thing I didn't remove that
TechnicianBrian
#4 Posted : Sunday, March 29, 2009 7:35:25 AM(UTC)
TechnicianBrian
If it melted the belt, then something is stuck, more likely between the impeller and the housing, or at the bushing and shaft. I would replace the pump because a water leak will probably be the next problem.
mom01
#5 Posted : Sunday, March 29, 2009 7:42:19 AM(UTC)
mom01
One more thing the hoses on the pump are very hard to remove when I replace the pump do you think the top wwould be the same so I only replace the bottom half????
TechnicianBrian
#6 Posted : Sunday, March 29, 2009 7:45:56 AM(UTC)
TechnicianBrian
They should be hard to remove given the age and that they need to be water tight. Just work them off using a small screwdriver and a back and forth motion. Then change the pump.
mom01
#7 Posted : Sunday, March 29, 2009 7:49:28 AM(UTC)
mom01
thanks, you've been very helpful will let you know how it goes
TechnicianBrian
#8 Posted : Sunday, March 29, 2009 7:50:12 AM(UTC)
TechnicianBrian
Glad I could help.
Siemens dishwasher pump keeps running (Dishwasher Repair)
by Fweigel 12/30/2023 4:35:28 AM(UTC)
Kitchenaid dishwasher pump? (Dishwasher Repair)
by Guest 6/11/2023 10:15:41 AM(UTC)
Mystery Ball Check Valve Shows Up In GE Dishwasher Pump (Dishwasher Repair)
by lokar 9/29/2021 8:04:19 AM(UTC)
washer pump (Washer Repair)
by smiller123 9/25/2014 5:45:50 PM(UTC)
Frigidaire Dishwasher Pump Wont Stop (Dishwasher Repair)
by badblue06 8/3/2014 6:54:58 AM(UTC)
Whirlpool Washer Pump Cover won't BUDGE (Washer Repair)
by 1John5vs7 7/16/2014 8:18:37 PM(UTC)
Whirlpool Washer pumps water AFTER cycle complete (Washer Repair)
by veedubbayou 6/29/2014 8:26:33 AM(UTC)
washer pump replecement (Washer Repair)
by Pat V 8/18/2013 3:52:24 PM(UTC)
Frigidaire dishwasher pumps water but doesn't wash (Dishwasher Repair)
by woodstock 3/19/2013 7:00:51 AM(UTC)
Maytag Washer pump out problem. (Washer Repair)
by ritewaykay 4/17/2012 8:15:07 PM(UTC)
GE dishwasher pumps water out right away (Dishwasher Repair)
by redbeard 3/26/2012 8:23:13 AM(UTC)
Lubrication for KitchenAid Dishwasher Pumps and Seals (Dishwasher Repair)
by jsz 12/26/2011 4:36:43 PM(UTC)
Putting in a new washer pump (Washer Repair)
by jerrypro 12/22/2011 10:26:18 AM(UTC)
Change washer pump on front load LG ? (Dishwasher Repair)
by jerrypro 12/22/2011 10:17:25 AM(UTC)
Dishwasher pump not working (Dishwasher Repair)
by traain 12/20/2011 3:17:04 PM(UTC)
