marshken
#1 Posted : Thursday, June 14, 2012 10:17:39 AM(UTC)
marshken
I have a Kitchen Aid frig with an Ice maker issue. It does not make any ice. The water dispensor works, the LED appears to work (it stays lit with the door open and the beam blocked). I am assuing the solaboid valve works (tried to swap plugs with the water dispensor but the spade connectors are different size). I removed the Ice Maker and found it had some corrosion in it and the coating on the aluminum tray is comming off so I am going to replace the ice maker itself for sure. My concern is that when I measure the voltage at the Ice Maker plug in the freezer I'm only getting 34 volts. Is this an indication of a bad control board?
I appreciate any assistance I can get.
Simon / APP Team
#2 Posted : Thursday, June 14, 2012 11:03:21 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Here the test for the optic control.
Thank you.
Simon.
File Attachment(s):
marshken
#3 Posted : Tuesday, June 19, 2012 7:25:54 AM(UTC)
marshken
I'll give this a try tonight and see how it goes. I'll post the results tomorrow.
Originally Posted by: Simon / APP Team Go to Quoted Post
Hi.
Thank you.
Simon.
Simon / APP Team
#4 Posted : Tuesday, June 19, 2012 11:25:40 AM(UTC)
Simon / APP Team
Groups: APP Team
Good luck.
Simon.
marshken
#5 Posted : Friday, June 22, 2012 7:03:02 AM(UTC)
marshken
Replaced the Ice maker and all is well. Thanks for your help
Good luck.
Simon.
Simon / APP Team
#6 Posted : Friday, June 22, 2012 10:08:36 AM(UTC)
Simon / APP Team
Groups: APP Team
You are very welcome.
Simon.
Guest (4)
