khb33
#1 Posted : 13 years ago
khb33
Hi, my in door water & ice dispenser is dead. Ice maker still makes ice. Anyone have an idea of what it might be?
Thanks, Kevin
#2 Posted : 13 years ago
Hi Kevin,
Remove the dispenser front cover (the instructions are attached) and check the parts inside. Post the results.
Here are the breakdown diagram and Dispenser front replacement parts for Whirlpool GC5THEXNS02 REFRIGERATOR | AppliancePartsPros.com
File Attachment(s):
Ice and water dispenser since 1997.pdf (195kb) downloaded 9 time(s).
khb33
#3 Posted : 13 years ago
khb33
I'm getting 120V at the control board.
#4 Posted : 13 years ago
Kevin,
What about all other dispenser parts?
khb33
#5 Posted : 13 years ago
khb33
Everything else looks fine.
#6 Posted : 13 years ago
Looks like the solution is to replace the front cover assembly. If you need the correct part number, post the color of it.
khb33
#7 Posted : 13 years ago
khb33
But how can you be sure if it is the front panel, or the circuit board behind the panel?
#8 Posted : 13 years ago
It comes together as assembly. Look at #23 at the diagram.
khb33
#9 Posted : 13 years ago
khb33
You are wrong on this model---the front panel is separate from the circuit board.
#10 Posted : 13 years ago
You definitely can separate them but the question is: does Whirlpool sell them separate? If you look at the diagram and parts list, then you'll see it.
