2 Pages<12
swede48
#11 Posted : Tuesday, June 12, 2012 4:01:02 PM(UTC)
swede48
Originally Posted by: msanchuk Go to Quoted Post
anyone know how to tell me what to do to initiate the adaptive defrost without waiting for the time to elapse?
there is a test pin and start pin that can jump make go into defrost.
dnicks
#12 Posted : Monday, June 18, 2012 9:47:26 AM(UTC)
dnicks
this is just a great bit of information :rolleyes: . i'm pretty sure the person asking the question realizes there is a way to push it into defrost, how about letting them know HOW to do it.
swede48
#13 Posted : Monday, June 18, 2012 5:37:04 PM(UTC)
swede48
the way to do it is in the frig area on right upper top is where adaptive defrost is. If take down the control levers. there are two screw (philips) and two nuts driver screws 1/4 in head. to get to them have pull down cover by pulling down forward part and back and slide forward towards you. then remove 2 screw and 2 nut driven screw. there is on back of frig. when all parts down you can get to adaptive defrost. It held in by 2 screws. on circuit board there is pin called test and 1. If you jumper them by screw driver or use wire it will send the defrost timer and heater in the freezer part to defrost. then if it does then it working right.
swede48
#14 Posted : Monday, June 18, 2012 5:37:04 PM(UTC)
swede48
2 Pages<12
