wright4s
#1 Posted : Tuesday, June 12, 2012 11:29:45 AM(UTC)
wright4s
My fridge is about 18 months old and just started making a noise like a fan in the back at the bottom is hitting something. Nothing out of the ordinary has been done to the fridge so can't understand what is wrong
Simon / APP Team
#2 Posted : Tuesday, June 12, 2012 6:30:57 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Pull the fridge out, remove the compressor cover and check if something got in the condenser fan blade.Use the opportunity to clean the condenser coils.
Thank you. Post the results.
Simon.
wright4s
#3 Posted : Monday, June 25, 2012 3:51:58 AM(UTC)
wright4s
Ok, well I can honestly say that I am no MS FIXIT!! and probably never will be. When I pulled out the fridge to have a look there was a sheet of paper underneath which I thought was possibly causing the problem, but no, it continued. Then my dilemma was how to get the screws on the cardboard at the back off and back on again. Well it took a member of the opposite sex to tell me that the screws were self tapping? at the time no idea what that meant. He took off the screws, moved the cardboard and found that a small piece of some kind of plastic or cellophane was stuck to the fan causing the noise. Definitely a quick fix. I thank you for all your help and will continue to consult on this site if needed.
Simon / APP Team
#4 Posted : Monday, June 25, 2012 10:56:08 AM(UTC)
Simon / APP Team
Groups: APP Team
You are welcome.
Simon.
GE GSH25JGDD WW making fan noise (Refrigerator & Freezer Repair)
by jmden 3/24/2022 5:42:11 PM(UTC)
Rattling Fan Noise from Kitchen Aid Oven (Oven Repair (including Ranges and Cooktops))
by agdodge4x4 8/22/2017 10:39:22 AM(UTC)
Fan noise on GE Profile Artica? (Refrigerator & Freezer Repair)
by rudybickel 1/26/2014 1:30:16 PM(UTC)
Double oven fan noise (Oven Repair (including Ranges and Cooktops))
by David R. Parker 6/25/2013 3:17:37 PM(UTC)
Evaporator Fan Noise - Fridge 50F (Refrigerator & Freezer Repair)
by trigram 5/28/2013 8:45:47 AM(UTC)
by rossco 9/3/2012 11:37:28 PM(UTC)
Evap fan noise? GE SBS (Refrigerator & Freezer Repair)
by Mrdj885 4/17/2012 12:47:36 PM(UTC)
Fan Noise from Evaporator Fan (Refrigerator & Freezer Repair)
by jackw 10/6/2011 1:16:34 PM(UTC)
condenser fan noise. (Refrigerator & Freezer Repair)
by garystarh 8/30/2011 6:33:42 AM(UTC)
Loud fan noise (Oven Repair (including Ranges and Cooktops))
by KeithWC 4/9/2011 8:50:54 AM(UTC)
Condensor Fan noise (Refrigerator & Freezer Repair)
by gtl545 2/21/2011 9:03:37 AM(UTC)
Jenn Air oven fan noise (Oven Repair (including Ranges and Cooktops))
by IreneSN99 1/19/2011 10:41:37 AM(UTC)
GE side by side with freezer fan noise (Refrigerator & Freezer Repair)
by TOPGLOCK 4/10/2010 9:37:02 PM(UTC)
Loud fan noise? (Microwave Repair)
by cfr 7/29/2009 7:57:38 PM(UTC)
Fan Noise ... maybe? (Refrigerator & Freezer Repair)
by acudocdns 6/10/2009 7:28:46 PM(UTC)
