jctr
#1 Posted : Sunday, June 10, 2012 1:57:38 PM(UTC)
jctr
The lights work fine, but the vents(microwave vents and exterior vents) don't. The microwave heats fine as well. That means it has to be the motor then right? Definitely not the circuit board or anything electrical?
Thanks in advance!
#2 Posted : Monday, June 11, 2012 1:58:05 PM(UTC)
The model number you posted does not come up. Verify and repost it please.
jctr
#3 Posted : Monday, June 11, 2012 6:28:08 PM(UTC)
jctr
#4 Posted : Tuesday, June 12, 2012 4:56:29 PM(UTC)
There is only one fan motor in this microwave and it works as a cooling fan and an exhaust fan at the same time.
Check the motor as described in the attached Tech sheet and post the results.
File Attachment(s):
Tech Sheet - 8206435 - MH1170XSQ0.pdf (545kb) downloaded 2 time(s).
Guest (4)
