smnweisen
#1 Posted : Sunday, June 10, 2012 2:26:49 PM(UTC)
smnweisen
Groups ready for retrieval: Registered
Hi guys! This whirpool washer gets no cold water.I initially thought that only on rinse cycle but when i selected cold water only on initial wash cycle, water barely came out. When I selected "Warm-Cold" option, water came out obviously in main wash cycle but not on rinse cycle. I opened it up and checked the voltage to water inlet valve, it's getting 120v in the rinse mode.. any suggestions? Thanks
#2 Posted : Monday, June 11, 2012 2:10:40 PM(UTC)
The problem can be a clogged screen inside the water valve or a bad water valve itself. I would recommend to replace the water valve because the part is no expensive and will make the repair more reliable.
- The water valve Part number: 285805
Part number: 285805
The model number you posted does not come up. The closest model number I found is LSR6132EQ1.
smnweisen
#3 Posted : Friday, June 22, 2012 8:11:55 PM(UTC)
smnweisen
Gene thanks the reply, I'v replaced the valve and it's working fine.
#4 Posted : Monday, June 25, 2012 8:56:19 PM(UTC)
You are welcome. I'm glad it's up and running.
