Hi there,
I have a GE side-by-side fridge. I'm having a problem with the check valve above the MWF water filter. Basically, when I remove the old water filter, the check valve is leaking water.
Any solutions?
Thanks.
Groups: APP Team
Hi.
Please provide the complete model number of the unit.
Thank you.
Simon.
The fridge is a GE GSS25XSRD SS
Groups: APP Team
Wow. Thanks Simon.
I looked at the breakdown diagram but didn't see how to install the filter head and tube. Do you have any other diagrams or manuel showing how to change that part out?
Thanks again.
Groups: APP Team
Hi.
Remove the water filter, pull out the cover. The base should be attached by two screws. Use common scenes.I could not find any step by step.
Thank you.
Simon.
