Refrigerator froze up. Replaced defrost thermostat. Two weeks later, refrigerator section warmed up to 40 degrees. Freezer coils had light, snowy frost and damper door appears to be intermittant. Evaporator fan motor seems ok and all vents are clear. Defrost thermostat and heater ok. Suspect Jaz board failure or bad fridg. section thermister. Hope someone has seen this before. Thanks in advance.
I would agree with the Jaz board as being the problem. It seems any inconsistent behaviors out of those models always leads back to that board.
