Spudboy
#1 Posted : Friday, June 8, 2012 1:30:19 PM(UTC)
Spudboy
To start this washer did not spin out.I checked everything.No damage apparent,but wax motor was melted and would not work.I replaced it and then the washer would not agitate or spin.The motor makes a small thump and rotates slightly about 3 to 5 times. Nothing burnt, it fills,shuts off the water,times itself and that is it.Tried a good used motor no effect.
#2 Posted : Friday, June 8, 2012 5:17:16 PM(UTC)
Make sure both door lock switches are properly engaged when the door is locked.
Here are the breakdown diagrams and Door shroud & door latch assembly replacement parts for Maytag MAH20PNAWW MAYTAG LAUNDRY (WASHER) | AppliancePartsPros.com
