blip01
#1 Posted : Saturday, March 28, 2009 12:30:37 PM(UTC)
blip01
I have the part #s for both the pre and post filter valves but would like to know if one is usually more likely to be causing the leak, or should I just replace both?
Thanks!:)
woodchuckie
#2 Posted : Saturday, March 28, 2009 6:45:49 PM(UTC)
woodchuckie
the water goes through the pre filter valve first so couldn't leak anywhere if that valve didn't.
blip01
#3 Posted : Sunday, March 29, 2009 10:05:31 AM(UTC)
blip01
Thanks for the reply. That's what I thought, but it also seems like if the second valve is good wouldn't that stop the flow even if the first one leaks?
