Gschrader0913
#1 Posted : Friday, March 27, 2009 6:06:24 AM(UTC)
Gschrader0913
Soap dispenser cover won't stay closed. How do I repair or replace?
applianceman
#2 Posted : Saturday, March 28, 2009 11:37:45 AM(UTC)
applianceman
Inside the door there is sound insulation, over time this insulation will slip down the inside of the door. Sometimes this will cause the soap cup not to close properly. Remove the screws all the way around the inside of the door then lift the inside half of the door up and you should be able to see if this insulation is causing your problem. If so remove it and your problem will be fixed.[URL="http://www.appliance-repair-it.com/dishwasher-repair.html"][/URL]
Gschrader0913
#3 Posted : Monday, March 30, 2009 5:54:07 AM(UTC)
Gschrader0913
I don't think insulation is the problem. The soap dispenser cover closes ok but won't stay locked in the closed position. It is supposed to stay closed until tripped open at the proper stage of the timer cycle.
applianceman
#4 Posted : Monday, March 30, 2009 12:43:02 PM(UTC)
applianceman
The insulation that I am referring to will cause this problem and is the most likely. But the spring on the cup cover may be broken. Also there is a spring at the timer that can be broken causing this problem. In any case you will have to take the inter door off to see. [URL="http://www.appliance-repair-it.com/"][/URL]
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 6/17/2024 7:34:54 AM(UTC)
Dishwasher won't work. (Dishwasher Repair)
by Guest 5/23/2024 6:32:18 PM(UTC)
High-pitched noise with LG dishwasher (Dishwasher Repair)
by Guest 5/17/2024 5:13:53 AM(UTC)
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Bosch Dishwasher dirty water in filter " hole" (Dishwasher Repair)
by Guest 5/14/2024 9:47:25 AM(UTC)
Bosch dishwasher SHVM78Z53N/01 (Dishwasher Repair)
by Guest 5/8/2024 8:58:29 PM(UTC)
Continuity TEst Samsung p/n 33299012 Dishwasher Water Inlet Valve. (Dishwasher Repair)
by cprodave 4/27/2024 6:55:56 PM(UTC)
Samsung DMT400RHS Dishwasher Over Level Water Error. (Dishwasher Repair)
by cprodave 4/27/2024 6:24:56 PM(UTC)
Samsung Dishwasher Water Inlet Valve--how to Test? (Dishwasher Repair)
by cprodave 4/27/2024 6:18:51 PM(UTC)
Kitchen aid dishwasher bottom leaking (Dishwasher Repair)
by Guest 4/21/2024 10:31:25 AM(UTC)
Bosch Dishwasher SHE3ARF6UC/22 E15 Error (Dishwasher Repair)
by codyace 3/29/2024 11:51:41 AM(UTC)
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
Bosch Dishwasher Display Goes Out After Latching Door (Dishwasher Repair)
by Guest 3/11/2024 7:00:18 PM(UTC)
Kenmore 90 665 dishwasher noise from impellor (Dishwasher Repair)
by Guest 3/10/2024 12:30:08 PM(UTC)
