My Frigidaire dishwasher, model FDB2510LCC1, will start and fill with water, but then once it stops filling with water it will not go to the wash cycle. It sits idle for a few minutes, then drains, and repeats. I have taken the motor and all assemblies apart and can no find debris or obstruction. Everything is very clean and appears to be in working order. It stopped working a couple months ago and I replaced the water inlet valve and cleaned all the internal components and it went back to working fine, but has now stopped again.
THIS FORUM IS DEAD!!!!!!! |
Thanks. I tried all the different settings and it reacts the same way. I took the motor out last night and it tested bad when I tested it for continuity and I tried to hook power directly to the motor and it would not run. I ordered a replacement motor from appliancepartspros and hopefully that will fix it.
