wcampbell
#1 Posted : Wednesday, June 6, 2012 10:03:56 AM(UTC)
wcampbell
We need to replace the Electronic Push-Button Switch Membrane on our dishwasher.
Can we get instructions on how to do this? I am not exactly sure of the age of the dishwasher.
I did call and get the part number 9743241, to order this part on-line (which is cheaper) on the ********************.ca website the ******************** number is PS402286.
#2 Posted : Thursday, June 7, 2012 2:25:24 AM(UTC)
Replacement parts for Whirlpool KUDS24SEWH3 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com
I am a bit confused your post says the membrane has to be replaced but the numbers you give are for the switch assembly.
If you click on Item 2 in Section 1 a new page will open with a Q&A section which has some install help.
If your problem is that some of the keys do not work then it could be just dirty connectors.
Connector Cleaning / Checking
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
