farmerjack
#1 Posted : Monday, June 4, 2012 6:31:35 AM(UTC)
farmerjack
I have a Kenmore Elite dryer that just quit heating. I checked the thermal fuse in the fan housing and it seems okay. I also check the thermostat, thermal fuse and heating element and they all show continuity (NC circuits). What else should I check to see why it won't heat. All other functions seem normal.
thanks,
#2 Posted : Tuesday, June 5, 2012 1:44:18 AM(UTC)
Replacement parts for Kenmore 11064992300 | AppliancePartsPros.com
You mention 2 thermal fuses so I am assuming you checked the thermal fuse and the thermal cur-off.
I would check the power.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
Next try the diagnostics.
If OK
Unplug the unit and swap the motor and heater relays.
I believe they are the same but double check this before swapping.
File Attachment(s):
64992300.pdf (390kb) downloaded 18 time(s).
Kenmore dryer won't heat (Dryer Repair)
by scruise 8/25/2013 8:02:47 AM(UTC)
by kypalak 1/13/2011 7:22:15 AM(UTC)
Kenmore dryer won't heat up (Dryer Repair)
by muskymike 1/15/2009 8:22:21 AM(UTC)
