We have a kenmore top load washer that spins but not at full speed. The clothes are not fully span out and the dryer takes twice as long to dry.I can hold the bucket when the spin cycle starts and hold it no problem from spinning. Like i said it spins, but sloooowly. Any help on how to fix it will be appreciated! I posted earlier and was asked to see if bucket is loose. I checked and side to side it seems to be. I can push the bucket all the way to the side of washer. If i try to pick up on it it seems to be tight. There is no play in it. Also the thread says less than one year but the washer is actually about 8 years old.
The CLUTCH needs to be replaced, The part is in the $35-40 range and I do them in less than 30min. (I've done at least 50 of them) a 1st timer would take 1-1.5hrs.:D
