2 Pages<12
amorak
#11 Posted : Monday, June 4, 2012 11:41:53 AM(UTC)
amorak
To bypass the bimetal, do I simply remove it from the circuit and connect the two wires? I believe so, but want to confirm....
#12 Posted : Tuesday, June 5, 2012 12:57:00 AM(UTC)
Yes you could do that.
There is also a TEST (shorting) pins on the defrost control board, see the tech sheet.
2 Pages<12
