mtthompson
#1 Posted : Friday, June 1, 2012 7:09:05 AM(UTC)
mtthompson
My washer started to leak water from the bottom front and was making a hig pitched sound. I replaced the pump and it stopped leaking during a cycle, but sound continued and I found water on the floor hours after I ran a load. I tried another load to help me isolate the sound and it got much worse during the spin cycle, then there was a loud clunk. I shut it off immediately and again hours later there was a little bit of water. Help!!
Simon / APP Team
#2 Posted : Friday, June 1, 2012 4:58:54 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
You should remove the cabinet, bypass the lid switch and run the washer to pin point the noise and the leak sours.Try to remove the pump first, then the motor.
Post the results.
Simon.
