Menard70506
#1 Posted : Friday, June 1, 2012 11:57:33 AM(UTC)
Menard70506
MY WHIRPOOL WASHER WILL AGITATE BUT WILL NOT SPIN OR DRAIN WATER. WE HAVE CHANGED THE LID SWITCH TO NO AVAIL. WE HAVE TAKEN THE MOTOR OFF AND THE COUPLING LOOKS FINE. ALSO BY APPEARANCE THE MOTOR LOOKS FINE. COULD IT BE THE STARTER CAPACITOR?? PLEASE HELP :confused:
Simon / APP Team
#2 Posted : Friday, June 1, 2012 3:03:11 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
If the motor is humming on spin check the contacts at the motor disconnect plug and wire harness for internal breaks.
The start capacitor should be fine because the washer agitates.
Try to run the motor while it's not installed.
Thank you. Post the results.
Simon.
