jbboyce
#1 Posted : Thursday, May 31, 2012 6:13:59 PM(UTC)
jbboyce
I have a Maytag Performa dryer that won't turn on,the timer works. I traced it down to either the T stat switch part number 53-2880 or motor. The motor rotates by hand so not locked up. Can The t stat switch enable a dryer not to start up?:confused:
#2 Posted : Friday, June 1, 2012 2:45:46 AM(UTC)
Replacement parts for Maytag PYE4500AYW DRYER- ELE | AppliancePartsPros.com
Seems the wiring diagram included in the parts is for a gas unit and I cannot find one for this unit so I am using info I have on other units in this series (PYE).
I doubt it is the Tsat you gave as this is the cycling (main) thermostat and only effects the heat.
More likely it is the thermal fuse (Item 5 in Section 5)
It kills power to the motor and the drum light, if you have one. The timer will still run.
Unplug the unit and one side of the thermal fuse and check it with a meter, should be 0 ohms.
If it is blown you will have to find out why.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 10 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it so the thermal cut-off blows.
The hi-limit should have regulated the temperature so the fuse did not blow, that is why there is a new one with the thermal cut-off..
Note: That unless there is another problem in the unit the hi-limit should never have to open. It is just a safety device with the fuse being a backup safety device.
Just in case it is not a grounded element.
With all the below the high limit will also have to be replaced.
Check that the belt is OK.
Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system.
Check/clean the blower wheel.
If all OK you may want to replace the cycling thermostat as it's contacts may not be opening (welded shut)
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
dryerdown
#3 Posted : Thursday, December 13, 2012 5:46:15 PM(UTC)
dryerdown
Hello I have a similar situation as mentioned in the original post. My question is; is the themal fuse normally open or closed. I noticed in the suggested testing that it should read 0 ohms which indicates it's open, but I am unsure if this is normal or do I have a blown thermal fuse? I have also checked the element and it reads 11.7 ohms and there is no indication of a short. I first noticed there was an issue when I had a burning smell coming from the dryer. My first indication was a bad motor, cause I replaced the belt about 3 months ago. But with the safeties it sounds like the motor may be good. Please Help!
#4 Posted : Friday, December 14, 2012 1:37:16 AM(UTC)
dryerdown
No, 0 ohms is open not closed. It is zero resistance to the flow of current.
Open is infinite resistance.
Is your model number the same as the original poster?
dryerdown
#5 Posted : Saturday, December 15, 2012 5:16:18 AM(UTC)
dryerdown
Denman, thanks for the reply. I figured it out. I had a blown fuse.
