I inherited this Bosch dishwasher but I'm not able to figure out how to stop the it from leaking water out of the top of the water inlet on the fill cycle. I took a video of what was happening to show exactly how it happens. What could be causing this? Bosch Dishwasher Water Inlet Leak - YouTube
Groups: APP Team
Hi. The water inlet system should be replaced Part number: 263833
Check the Q and A. Thank you. Post the results. Simon.
How would replacing that part help? I've compared it to other correctly functioning parts and it is the same with nothing broken internally.
Groups: APP Team
It's got to be a restriction in the water inlet system witch caused the overflowing.
Simon.
I'm curious; did you watch the video? The water is flowing through the inlet assembly and into the bluish float assembly. If there is a restriction, wouldn't it be from the float assembly forward? Wouldn't this back up the water in the inlet assembly?
Originally Posted by: Simon / APP Team ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) It's got to be a restriction in the water inlet system witch cost the overflowing.
Simon. It turns out that the access valve (water inlet valve) is exactly what the issue was. Once the valve was replaced the water level was correct and there was no overflowing. There was no restriction in the water inlet system "which caused" the overflowing. There was simply too much water getting in. There is an internal diaphragm to the water valve that regulates water flow; this diaphragm was not functioning as designed. $36 part versus an $80 part.
Groups: APP Team
Thank you for very helpful information.
Simon.
