erma
#1 Posted : Friday, March 27, 2009 4:37:46 PM(UTC)
erma
Dryer wont come on. dryer door missing door closer clip. is that the problem? also would like to see a diagram of how the door switch works to activate the starter switch.
#2 Posted : Saturday, March 28, 2009 2:34:43 AM(UTC)
Could not find any info with given Model Number.
Please check it.
Yes the door clip could be the problem.
Actuate the door switch manually. You may have to use a pencil or some other device to do this.
Just do a quick check. You could blow a thermal fuse if run too long with the door open.
Now does it work?
kayakcrzy
#3 Posted : Saturday, March 28, 2009 4:26:50 AM(UTC)
kayakcrzy
if the door is not hitting the little arm that is attached to the door switch, that could very well be your problem. the part # on the door switch is 279347. if that is not the problem it will most likely be your thermal fuse, which is located in the back of the the dryer, and is white in color, and has 2 wires going to it. you can jump out the thermal fuse by takeing the 2 wires off, and putting them together with a little tape, and then plugging the dryer in and see if it works. do not run the dryer with the fuse jumped out. it is a saftey devise, and this advise is for diagnosing only. the part # on the thermal fuse is 3392519. tom
Thermador double oven from '99 troubleshoot (Oven Repair (including Ranges and Cooktops))
by mike_balt 5/6/2024 4:16:42 PM(UTC)
OEM or Aftermarket Replacement Bake Element? (Oven Repair (including Ranges and Cooktops))
by lbb78 4/18/2024 10:05:55 AM(UTC)
thermador double wall oven (Oven Repair (including Ranges and Cooktops))
by Guest 4/8/2024 11:57:14 PM(UTC)
Removing igniter from thermador star (Oven Repair (including Ranges and Cooktops))
by Guest 2/24/2024 9:17:28 AM(UTC)
Thermador SEC301BP Display Dim (Oven Repair (including Ranges and Cooktops))
by tower154 2/11/2024 7:34:06 AM(UTC)
Thermador oven won't start self clean (Oven Repair (including Ranges and Cooktops))
by beb123 2/6/2024 7:34:41 PM(UTC)
Heating issues with Thermador Oven (Oven Repair (including Ranges and Cooktops))
by Guest 1/9/2024 4:34:19 AM(UTC)
Downdraft Thermador exhaust (Oven Repair (including Ranges and Cooktops))
by Guest 12/30/2023 2:38:37 PM(UTC)
Thermal fuse ratings and interchangeability on dryers (Dryer Repair)
by Guest 12/17/2023 10:57:55 AM(UTC)
Broken Roller Support for Upper Rack - Thermador DWHD770CFP/22 (Dishwasher Repair)
by Smimo4708 12/11/2023 11:28:47 AM(UTC)
Kenmore Dryer blowing thermal fuses (Dryer Repair)
by Marius 11/21/2023 2:26:28 PM(UTC)
Thermador modern internals into retro hood? (Oven Repair (including Ranges and Cooktops))
by Guest 8/27/2023 5:02:55 AM(UTC)
Thermador Range Hood - buttons blinking and fan difficult to control (Oven Repair (including Ranges and Cooktops))
by alanmiller 8/12/2023 9:51:57 AM(UTC)
Thermador Gas oven won't light (Oven Repair (including Ranges and Cooktops))
by Guest 8/1/2023 8:48:27 AM(UTC)
Thermador wall oven temp sensor (Oven Repair (including Ranges and Cooktops))
by dxg2 6/4/2023 11:36:40 AM(UTC)
