dseah88
#1 Posted : Tuesday, May 29, 2012 2:56:01 PM(UTC)
dseah88
Hi, my oven door opens nicely but when I bring it up and close the door it will make a loud pop and the door will fall about an inch. Not fall open but just literally drop down by 1 inch. I have removed the door and reinstalled a few times to no avail. Could the hinge be bad? I removed them both and they seem to be fine. Just a simple spring and arm - I don't see anything wrong with them. Any help would be appreciated. Thanks
Simon / APP Team
#2 Posted : Tuesday, May 29, 2012 5:06:22 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Most likely there are bad hinge receptacles Part number: 73001063
Check the groves on the hinges too.
The hinge Part number: 73001109
Here are the breakdown diagrams and Replacement parts for Jenn-Air PRG3000P RANGE- S/C F/S GAS | AppliancePartsPros.com
Thank you. Post the results.
Simon.
Frigidaire Electric single wall oven door issues (Oven Repair (including Ranges and Cooktops))
by Dhower 12/2/2009 11:01:49 AM(UTC)
