it started with no lites to control board, changed hv board to restore. added code 1720 to reset. found that the compressor start relay rattled so i replaced it. now it appears to run but not cool. checked winding s of compressor with resistances of r to c 4.2 ohms,s to c 7.4 ohms, and r to s 12.5 ohms. not resistance to case on all contact points. compressor when on does not get hot. condensor,evapoator,and ice maker fans run. evaporator coils do not get cold and the defrost is not hot. from control panel i entered the service code check list,code 101 off,102 runs, 112 and 113 runs 0.0-7.75-12volts,121 -131 toggle,141 temp 79,142 temp 75, 144 temp 86,and 145 temp 75,151-152-153-163-164-165-167-168-171-172-175-182-193 toggle. 182 lites blink.192 off. no changes from default 201-202-203-211-212-213. used 221 to set to default.did not enter service tests, i did record readings.301 ---,308-309 0.0,311 to 317 25.5,318-3119 0.0,321 ---,328-329 0.0, 331 ---,338-339 0.0,341 to 347 ---,348 349 0.0, 351 ---,358 0,359 na,401 na, 501 on. what do think is the fix?:eek:
